60-1 and oil feed restrictor fitting?
mott6904
Car: rb20 big turbo big cams s13, 97 kouki, turbo audi a4,turbo busa
I have a rb20 with a 60-1 turbo and n1 oil pump, feed line i used is a -3 line and fittings. Im having a problem where it smells like oil and on start ups it smokes a little or under hard pulls. since i have a n1 pump do i need to put a restrictor on the feed or not. If i do do you think i blew my seals out allready. I have only ran the turbo for less than 100 miles.
moso240
Car: Ferrari V12 Powered S13
rb20? if so when does she reech full boost? and what are your mods... Sorry for the off topic but im doing somthing similar
BoostFab
Car: S13cp, S13fb, S14z
the 60-1 is a bit bigger than the standard t3. since you are using AN-3 line, you may not need a restrictor.
if you want to add an extra security:get one of these : http://www.atpturbo.com/Mercha...-OIL1
or you can make one yourself by weld shut the adapter and drill a hole in equivalent diameter.
mott6904
Here the deal i bought the turbo used for 100 bucks but when i got it the thing was shot(shaft play and bent wheels). It had a restrictor on the feed but i was worried about it not getting enough oil and that is why the bearing failed. So i bought a new center section and everything is fine. Im running a n1 oil pump and that thing is putting out about 50 psi at idle and is putting out over 100 before the turbo even spools up and thats why im thinking it is getting too much oil. I have put to much money into the car allready and i dont want to buy another turbo when i could spend it on something else.
mello88
Car: s13
Hi, are you running HKS cast low mount manifold? I have the same setup with a T3T04E, using a NPT to AN-4 fitting no the turbo then a AN-4 90' eblow for my oil feed line. I have an NPT-NPT .065 restrictor, but I can't use it because the restrictor+NPT/AN adapter height is so tall that the nut on the AN-4 line hits on the turbo flange.. Just wondering if you might have the same issue on your setup. I like the idea of welding/drilling the NPT/AN adapter, I might do that instead.
If I were you I'd try to run the restrictor, the turbo doesn't need a lot of oil pressure to stay lubricated. I think I read somewhere it only needs like 20psi. I think 100psi is definitely too much pressure and probably is going to or already has blown your seal.
mott6904
right now im running a npt -an fitting to a low profile 90 or 120 down to the block and dont have a issue besides i think it is to close to the manifold. the restrictor i have is a low profile 90 that goes from npt to an fitting so it should be sit lower. Im going to earls to get some **** today and put it on i hope i didnt allready blow out the turbo i will be F**king pissed.
BoostFab
i do recommend the restrictor.even the T76 or the GT series turbo need a restrictor, especially with the N1 pump.
Largekid
Car: '96 RB S14 SE, '04 LS6 CTS-V
BoostFab wrote:i do recommend the restrictor.even the T76 or the GT series turbo need a restrictor, especially with the N1 pump.
I have a stock oil pump, but i'm running a T70 -3AN feed and -10AN return, and have no problems with to much pressure or anything.
mello88
Car: s13
mott6904 wrote:right now im running a npt -an fitting to a low profile 90 or 120 down to the block and dont have a issue besides i think it is to close to the manifold. the restrictor i have is a low profile 90 that goes from npt to an fitting so it should be sit lower. Im going to earls to get some **** today and put it on i hope i didnt allready blow out the turbo i will be F**king pissed.
That sounds like a little better setup, using the 90's. Where did you get the 90' elbow restrictor from? I thought it looked too close to the mani going straight to the oil port, so I went around & under the turbo near the water lines, with a 90 elbow off the block. I'd like to see pictures of you line, mani & DP setup if you have some! Doing my DP this weekend hopefully, with any luck it can be started next week.
I'd run the restrictor if possible, are you sure the last turbo seized from a lack of oil pressure and not something else? Do you have a turbo timer on your car? Ever experience low pressure or blockages in the turbo lines? Hope your turbo is still in good shape! GL
mott6904
What i mentioned before is my current setup with no restrictor. I went to earls and got some more fittings and i got a restrictor at a big turbo place in indy. Im going to post some pictures up here in a bit of what im working with. I have a -4 line instead of a -3
Modified by mott6904 at 9:16 PM 5/30/2008
mott6904
moso240 wrote:rb20? if so when does she reech full boost? and what are your mods... Sorry for the off topic but im doing somthing similar
Check my signature for a link to my pics
R32 rb20det Made my own mounts 60-1 turbo Hks 50mm wastegate hks bottom mount cast manifold Custom earsl turbo oil lines Ported and polished head Kelford 10.2 lift 260 duration cams kelford valve springsARP head studs Cometic head gasket cometic intake gasket custom front facing greddy style intake manifold q45 throttle body aeromotive regulator greddy fuel rail walbro pump z32 fuel Custom earls fuel lines Greddy type r bov Hybrid fmic Apexi filter Griffin radiator flex-a-lite dual pusher fans with built in shroud painless thermo switch nismo lower temp thermostatgreddy timing belt Oem tensioner and idler pulley N1 water pump n1 oil pump Gt spec exhaust custom 3' downpipe built be me built my own charge pipes Grand national coil conversion msd plug wires with custom made brackets. Aem tru boost controller Aem oil pressure gauge Quest alternator upgrade and custom bracket custom thermostat housing All pipes have thick couplers with t-bolt clampsAll new beltsAll new hosesAll new seals in the engineAll new fuel lines vacuum linesAll new fluidsI pulled this off of another thread
This is the oil restrictor that came on the used turbo i bought and one of the fittings i got at earls. the 90 has a jet pushed in the end of it. With this setup i should be able to keep the oil line closer to the center section instead of the manifold.
Here is the restrictor adapter i bought today at the turbo shop. It has a -4 an male fitting on top that has a oil on the bottom to seal it. The bad thing about this is that it positions the feed line close the manifold. i have a 120 degree fitting on my current setup that i would be using on the adapter plate. Oh yea another thing the plate is only drilled to .040, which i think might be for a ball bearing setup. I think i might have to dill it to .065 or .070 but if someone knows what it should be let me know.
I also bought this flame gaurd shield to wrap the line in to keep the oil cooler going into the turbo
