6 speed trans dimensions
Nissan 350z / Nissan 370z general community discussion forum
240rr
Car: 240z
NEVER MIND...I FOUND THE DIMS....THANKS!
Anybody have a 6 speed trans out of the car they can take a couple measurents of?
first off the Overall length
Then
If you are looking down at the trans from the top it kinda has three segments...bellhousing, gearbox and tailshaft/shifter mount.
Bellhousing area I need the distance from the mounting flange to the rear of that segment where it transitions to the gearbox area...along with the width at that area.
Then the length of the gearbox area and the width at the rear.
Hope this makes sense.
I am building a tube chassis 240z with VQ35DE and 6 speed and have not aquired the transmission yet. Basically trying to figure out the layout for the lower chassis tubes and the tunnel....
Return to “350z / 370z Discussion”
