You're right... The S15 transmission was under designed for what most enthusiasts do to it. It's essentially a 5 speed housing with 6 gears worth of crap in it so all of the gears are smaller. I would stay away from it.FRnIsmO wrote:not sure, what motor your putting it on? heard it spits gears when over 300 horses like the prelude atts sh transmission....hope i'm wrong though
also I know that 6th and 5th have the same ratio but 1th to 5th are closer togther, that means more torque,right?markex33 wrote:I think I've read somewhere about a signal converter the could use the same signal of the abs sensor and slow it.
