Toast wrote:I dont know how much they can handle but I looked into it and found out they are weaker because the gears are thinner so they could fit 6 gears in the 5-speed sr bellhouseing and that the 6th gear is pretty much worthless because it doesnt add and top end and you have an extra gear to shift into now. So yes it would be cool to have 6 gears but its not worth changing the diff and drive shaft while doing it.
6th gear on about 75% of cars that have them aren't for top end, they are for overdriving the drivetrain so that engines like a 346cid LS1 can get almost 30mpg on the highway. It's a cruising gear.
And all this noise about breaking transmissions... it's all about how you abuse it. There are TONS of people that have junked the 5-speeds ... ESPECIALLY the S13 5-speeds from the CA.
