6-speed Q45
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
jtmroczk
Car: 2010 6-speed FJC, 1994 6-speed Q45
still putting miles on the new clutch
[youtube]http://www.youtube.com/watch?v=j3_oV-GsEow[/youtube]
Chrispy300
Car: 1993 J-Spec 300ZX 5 Speed Slicktop
Z33 Gearbox?
What did you do for the speedo sender?
jtmroczk
yep, Z33 gear box
nothing yet, no speedo and no reverse lights at the moment, i was pushing to have the car drivable for a big event last Saturday.
HG50
Car: 91 Q45
15 4Runner
good s*** man
jaysol
Car: Super Black 1997 240sx/se
1995 Nissan 300zx Slick top-sold
Could you share with us how made this combo work? Did you design Adapter or what was the process in order to get the z33 transmission to bolt up to the vh45?
jtmroczk
the day by day from when i bought the car is http://vipstylecars.com/forums/showthread.php?t=16312
bsbiz11
Car: 94' Q45
Do you know of anyone I can contact to help with my Q conversion in Atlanta?
jtmroczk
Z32-5 or Z33-6 speed?
Elwesso on this forum has done his Q45-Z32 5-speed swap, there is another in progress in the Q45 section or are you looking pay a shop to have it done for you?
craigztoyz
Car: lots of unique hot rods, and customs, with modern engines, and a good truck to pull the trailer.
jtmroczk wrote:Z32-5 or Z33-6 speed?
I'm in Tx but have cars coming from South Africa, and Neatherlands, doing # 17 of the Z32/VH45 swaps, done a few other body styles too, RX7, 350Z, and a 48 chevy.
3500 turnkey, minus the clutch/flywheel, we leave that up to the customer to choose their options. Most go lighten'd with a 6puck, works well.
Not doing kits or parts anymore as some people are not smart enough to install them.
Not trying to sell, just informing and responding to the Q.
Craig
jtmroczk
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I like the guy at the end that shouted "HES GONNA FLIP OVER!!!"
Really nice drifting there... really putting the car through its paces.. :)
Kevin Phillips
Car: 350z
jtmroczk- please contact me i got some question. im doing a similar swap. 954 234 1122- Kevin
slipnslide88
Car: 97 VH45de Kouki
im thinking about a 6 speed conversion for my vh kouki. id like to talk to you a little bit more if you dont mind so I can gather a little more info
elwesso
2007 BMW M Coupe
I already have adapters to do the 5 speed in case anyone is interested.. :)
ghettoslide
Car: '90 240sx, '91 240sx, '98 DSM, '05 Avalance
Elwesso. I'm interested in a plate. I have the motor transmission and clutch set with flywheel. Contact me at [email protected]. planning on starting the build in a couple of weeks. Look for my build post soon.
dlucke17
Car: 04' Audi A4 Quattro, 06' TBSS, 93 240sx Coupe
Guys, need a little help...
JTMROCK, I have been following your build in hopes to doing the exact same thing and dropping into my S13. Here is my setup so far:
VH45 out of 91 q45
CD009 6-spd out of 07 350z
z32 flywheel 91 300z NON-TT
z33 clutch / PP 07 350z
Had the engine on it's nose, fit the flywheel and found longer flywheel bolts (can't use auto bolts of course)... Fit pressure plate to flywheel. Bolt holes lined up but had to drill new(er) pilot holes... THEN clamped up the starter and the gears are close to 1/2" - 1/4" off... I have read up that both Q45, z32 n/a and other models have the same teeth (124) on them so they should be interchangeable... RIGHT??!?!?
JTMROCK, I know you removed the q45 ring gear and put it on the z32 flywheel but WHY??? are the gears lower set on the flywheel, which would correct this issue??? I am thinking of grinding down the starter flange that connects to the engine, but still not 100% on it working... Any idea's here???
IThaJ0kaI
Car: 96 G50, 90 S13 hatch
The z32 and q45 flywheel gears are not the same size, this is why he put the q45 ring on the z32 flywheel. If you are wanting to use the q45 starter, you must use the q45 starter ring.
Carl H
the z32 na flywheel has the same od and tooth count as the q45 flexplate.
some material will need to be removed from the back of the flywheel to allow for proper starter engagement.
dlucke17
IThaJ0kaI wrote:The z32 and q45 flywheel gears are not the same size, this is why he put the q45 ring on the z32 flywheel. If you are wanting to use the q45 starter, you must use the q45 starter ring.
Sorry, but this is not true!!! z32 and q45 are exactly the same!!! The only difference is the point at which the starter engages the ring gear. For the z32, the starter is mounted on the transmission, behind the flywheel. So it engages the flywheel from the back of the car. The q45 starter is mounted to the engine, in front of the flywheel. Just the opps of the z32, it engages the flywheel from the front of the car. The simple fix is to heat the flywheel up, beat the ring gear off and quickly put it back on the flywheel. OR I have also read a couple people have used the Auto flexplate and then mounted the flywheel right behind it. Doing this would kill the reason to have to send off your bellhousing to get it resurfaced, as the added distance of the flexplate vs the added distance of the adapter plate are near exact... (I for one have NOT tried this, and cannot prove this point...) I can however prove my first point as that is how I have the motor to transmission setup right now...
We cut right behind the bolt flange of both the q45 auto and z33 transmission, and then alum welded them up...
BEFORE
AFTER
HERE IS A PIC OF THE FLYWHEEL / STARTER ENGAGEMENT...
STILL have plenty of work to do, but right now the biggest question is do I need the bracket that is shown in the pic below? The extra link for the transmission??? I have seen people cut this but I am not sure...
Carl H
punch the knock pin out and move the shifter cup to that location...you'll have to get a bit creative to make it work but that is the best way to do it.
if you do it right it will be dead center in the shifter hole.
jtmroczk
If it works go for it. What i know is the Z32 ring gear is facing the wrong direction for the q45 starter and has to come off. Whatever i measured a couple years ago said that they were not the same diameter, the difference was small but significant, and i can tell you once you put a q45 ring rear on a z32 flywheel, its not coming off, the inside diameters are different. So q45 starter ring on a z32 flywheel will give you just enough engagement to start the car. Grinding the back of the starter mount or shimming the starter ring are both good ideas for increasing starter engagement and reliability and longevity. If you had access to a big enough lath, turning the Z32 starter ring down to about 3mm while still on the flywheel would make a pretty sweet shim for the Q45 starter ring.
In regards to the bell housings, skipping the milling process is a major mistake, but i hope you get lucky. Out of six degrees of freedom it looks as though you have only constrained one, linear Y axis(plunge depth). Machining the bell housing constrains the rotational X and Z axis(leaning), where the rotational Y axis doesn't matter much. Machining also prevents any mishaps with linear Y axis(plunge) during the welding process. Leaving only the linear X and Z axis to be constrained by what every you set up to position everything for the welding process.
In 2008 iifc, I helped Ranlet put one of these on the back of an older Subaru block without machining the X and Z axis out of the equation. The input shaft ripped the splines out of the clutch disk later that year. If there is any deviation from 90 degrees in input shaft vs clutch disk, then the transmission input shaft splines contact the leading and trailing edges of the clutch disk splines and cause binding and cutting, psi becomes massive.
good luck, Its pretty damn sweet to see another Z33 6-speed stacked on a VH block for welding.
jtmroczk
I think this is the information you are looking for?
http://forums.hybridz.org/index.php/top ... ge__st__40
Return to “VH45DE / VK45DE / VK56DE Forum”
