SpecDRacing »
https://forums.nicoclub.com/specdracing-u28175.html
Fri Sep 26, 2008 5:19 pm
RS6F51H.....that is the designation for the Sentra SER V-Spec 6 speed transmission. RS6F51A is the designation in the Maxima without LSD and RS5F51A is the 5 speed transmission.
The third digit in the code is the number of gears. The last digit in the code is the type of differential. A = Open, H = Helical, V = Viscous (mainly used in RWD applications but was available in I30s and Maximas in the early to mid 90's).
The LSD in the 6 speed is a Helical type, meaning its pretty small, does not contain clutch packs and uses the oposition of gear rotation to "lock" the diff. The early M30 (infiniti) had this for a rear end.
Forget the Ring gear wrapped around the differentail. Where the axles go into your transaxle, there are splines. Each axle has its own set of splines that connect them to the differential (the big round portion that odly sticks back from your transaxle). Those splines are the inside of two seperate tubes (one for each axle). The other side of the tube has a gear on it. Imagine a barrel with grooves on the inside and teeth on the outside. Those outside teeth come in contact with 4 small gears (picture North South East and West of the teeth on the tube). So now we have two tubes with grooves, and 4 gears on each tube equaling 8 gears. Those gears are long enough to contact each other, even though the tubes do not. This is all held together by a case (carrier). When one turns, they all turn. So if one axle spins clockwise, and the case holding all the gears and tubes together is held stationary, the other axle will turn counterclockwise. When only the case is turned, and the pressure on the both axles is equal, they will both turn equally. There's more to it then that as some contain springs and others use different turning ratios of the helical gears to create a form of breakaway torque (that term is typicaly reserved for clutch type LSDs).
In an open diff, there is a pinion in the middle of the two tubes. It has a gear on each end shaped like a cone (side gears) and they are in contact with the case as it has teeth cast into it. This is good for gas mileage and hard to soft surface contacts (like one on the asphalt and one in the dirt). The down side, there is no limiting factor to keep the wheels spinning together with equal power distribution.
So, back to 5 speed or 6 speed. 5 if you like 1st gear.....6 if you need the ability to select just the right rpm to enter or exit a turn. Not much difference other than that. 6th is overdrive (I think it's 0.63:1) just as 5th is. The only difference is at what speed you'll redline your tach.
Maybe I can post some pics up of a HLSD for you.
