6 speed manual transmission noise
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Hotfoot27
Car: 2009 versa s
I have a 2009 versa s with 30,000 km's . The 6 speed manual trans has a whine between 60-90 km's per hour. Doesn't matter what gear its in or ir clutch is depressed. Anyone else have this noise? dealer said that original trans had bad bearing and replaced trans under warranty.
Return to “Versa Technical Discussions”
