6 lug to 5 or 4 lug possible?
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
FUJIBAYASHI
Car: 1989 Silvia Qs
ive seen those bolt on spacers that let you go from 6 lug to 5 lug... i dont even feel 5 lug is needed on this truck...
is it possible to swap out hubs from another nissan to make the 720 4 lug? or even 5 lug, if thats too tall of an order.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
sure why not? Is your truck 2wd or 4wd?
I think the only problem stems from the front drive wheels and their free spinning hubs, which need to be locked before using 4wd.(i think)
If you are 2wd then I am pretty sure you can get some 5 lug swap for a 240 and it could work. (not 100% sure tho, but nissan really likes using same or very similar parts across the models) //some Mazda parts also seem to fit right in nissans
FUJIBAYASHI
Car: 1989 Silvia Qs
my truck is 2wd.
what would i do about the rears though? could i swap out the drums for disc brakes..? and possibly just use 240 parts?
breadbox
89 Koop
84 720 4x4KC
I am hoping you can use either 240sx or some bigger brakes like z32 brakes front and rear, 5 lug swap, and wheels that can clear the brakes nicely.
Thread I started in the NICO Truck forum. If you have more questions might ask there, more people get to that part of the site.zer...id=36
FUJIBAYASHI
Car: 1989 Silvia Qs
thanks, i checked it out.
IThaJokaI
Car: '93 Nissan hardbody
I know these are older threads, but I figured I would share the info anyway.
You can run toyota 5 lug hubs in the front, along with a toyota rear axle and obtain 5x114.3 lug pattern.
All it takes is a simple machining of the stock spindle.
manic_mechanic;41744 wrote:1. Take your spindles to a reputable machine shop. Not Lickmy Tool & die.2. have them machine 1/4" off the spindle shaft collar. As the diagram shows.Bringing this diagram with you will be very helpfull for the shop.
breadbox
89 Koop
84 720 4x4KC
HOLY s***! I mean Niiice. Thank you.
IThaJokaI
^ no problem, I have alot of info for nissan/datsun trucks laying around.
breadbox
89 Koop
84 720 4x4KC
Whip it out. I'll organize it into a crazy thread. I am working off a Chilton Manual and ratsun(whatever I can find helpful to 720s). I read a bit of infamous nissan but mini trucking isn't necessarily my style. I read some of nissanoffroad, but info is here and there. I am hoping in the future Nissans will take up more of my time and I can start seeing what other brand parts work with it.
flylta
Car: 1982 Datsun 720 Diesal
Has anyone done a 4 wheel disc conversion?
Just getting started and thought of that right away.
IThaJokaI
flylta wrote:Has anyone done a 4 wheel disc conversion?
Yes, toyota had a truck with 5 lug and rear disks.
I also think there was a pathfinder with rear disks, although the axle would be wider than a stock 720 axle. And of course it would be 6 lug.
bk whitest
Car: 1980 Datsun 720
So why do you recommend for rear disk and the 5 lug adapter
Can I get sites cause I've found some but insure it they would fit
New to the datsun fam lol
Got. 1980 720 rwd trying to put all four disc with at least a 5 lug in the back front can wait for now
Return to “Datsun 720”
