ScottJackson »
https://forums.nicoclub.com/scottjackson-u14976.html
Sat Aug 11, 2007 1:02 pm
Yeah, the last two sentences weren't bad though. Ohming the injectors is testing the coil winding in the injector. This is an electro magnet which opens and closes the injector. A fuel injector cleaner won't reconnect broken/corroded wire windings. If you've got bad ohm readings at the wire harness (the way to check them without pulling the plenum) then you need either a new harness (not likely) or injectors (much more likely). Then, when you've got the plenum off you can go ahead and unhook the wire harness from the injectors and measure them directly. If a couple are dead, it's far better to replace them all with NEW ones than just the couple bad ones. Pulling the plenum is never fun, but then again, injectors aren't cheap and it's always easier for me to spend your money than for you to spend your money
