6.5" Components installed - pic intensive
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
williamk10
Car: '07 Nissan Versa SL
Phoenix Gold RSd 65cs Component speakers installed. Pics below
With the speaker bracket adaptor
Marked a hole for the hole saw
This will end you and all you love
Stock crappy paper cone speaker
PG installed with bracket adaptor
Crossover goes there
The biggest pain was getting the tweeter wire from the A pillar thru the grommet and rubber hose into the door. Other than that, straight forward install. The tweeters don't mount entirely flush so I may need to move it in the future.
And the speakers, they sound good. Lots of mid bass and the tweeters give the crisp highs the stock speakers just couldn't reach.
NODES
Car: 2007 Nissan Versa SL (Blue)
Good work. Wiring is such a pain in the A$$, but when done right it is well worth it.
CrankyVersa
Car: 2010 Versa 1.8 hatchback SL
Nice install friend. Yeah i noticed that the A pillar has a slight curve where the factory tweet sits. This is gonna be fun when i replace the factory components in mine LOL! BTW where did you get the adapters from? I will need a set or 2
williamk10
$16.99 a pair on e bay. Search for Nissan speaker adaptor.
After a few days of listening, I need an amp for them. Giving the components 20w RMS when it wants 60w RMS makes them sound weaksauce.
What do you guys think of this?
http://woofersetc.com/index.cf...=3806
CrankyVersa
That should work fine bro. They make good amps with good components. They should sound pretty sweet to be honest.
kartracer90
Car: 03 Mazda Protege5, 07 Nissan Versa
the Eclipse amps are great, efficient, clean, and have a small footprint. The one you have pictured it last years model the newer ea4200 is a little cleaner, and has newer technology that allows for a little more power. Great amps either way you look at them.
VersaMG08
Car: '10 Mazda 3 s hatchback
'14 Nissan 370z
Looks great man, are you running on a stock radio or aftermarket? I want to replace this 6 disc changer with something that sounds better.
williamk10
JVC KD-S100 HU
Pretty good, $109 after a $20 off promo code on Crutchfield. Came with dash kit and harness and antenna adaptor. USB, SD and CD-R support, motorized faceplate and a pretty nice DSP
VersaMG08
'14 Nissan 370z
Awesome, did you originally have the 6 disc changer with stock bluetooth?
williamk10
No, I had the base system with 4 speakers.
Sounded like crap
NODES
williamk10 wrote:No, I had the base system with 4 speakers.
Sounded like crap
are you replacing the back speakers as well?
VersaMG08
'14 Nissan 370z
You guys going to have both your Vs in a photoshoot together? Like brother, like friend!
williamk10
VersaMG08 wrote:You guys going to have both your Vs in a photoshoot together? Like brother, like friend!
With my stocks back on and the crap vancouver weather, maybe when springtime comes
i'll leave the back speakers for now. i'll be poor when xmas hits so it'll have to wait for later
NODES
I am up for it come warm weather
williamk10
Amp installed. The speakers are rated 60W RMS and I was only giving them 20W from the deck. This amp is rated 60Wx2 RMS so it was perfect. It pounds real nice now. Mid bass is great from these speakers but for the full experience, nothing beats the power a tight 10" or a deep 12" sub can produce. Not to mention the car shaking feeling it provides really adds to the experience.
So anyways, I need a sub now...
NODES
Subs are Music's Best friend
CrankyVersa
Check out Crutchfield.com I got my MTX 5500 10" for 70 bucks, was a great deal TBH.
superskunk
Car: '07 Nissan Versa S Hatch
'06 Nissan Murano SL
i picked up a second component set for my versa, now all i need to do is put it all in.... i cant wait till my system is put together, and then the hard part will be tuning my stereo and adjusting the 4 channel amp...
CrankyVersa
Yeah i am doing all of the prework now to get my system in. Just a small system to be honest:
MTX Thunder 5500 10"MB Quart coaxials for the front doors with factory tweets.MTX 4004 Amp bridged for subAudio Control EQX
Using the factory deck for now. I will replace it hopfully after X-Mas.
NODES
Will no grills on the tweeters?
CrankyVersa
They are behind a perforated opening in the pillars. I will be replacing them eventually though with a set of Quarts.
VersaMG08
'14 Nissan 370z
I still need to replace my tweeters. I changed out all the speakers though...
NODES
VersaMG08 wrote:I still need to replace my tweeters. I changed out all the speakers though...
same with me, rocking the stock tweet's till spring.
williamk10
The PG tweets makes my ears bleed at high volumes...those little suckers are loud.
Has anyone done any sound proofing on thier doors? I can't tell if the rattling is coming from the metal door or the door panel.
NODES
williamk10 wrote:The PG tweets makes my ears bleed at high volumes...those little suckers are loud.
Rattles in the doors... I have a rattle in the passenger side and it disappears if I open the window slightly. Too cold to deal with it now come spring time I will take the door apart again and may dynamat them and grease my window sliders while I am at it.
CrankyVersa
yeah i have done a TON of sound deadening in the years LOL. I like Dynamat Extreme myself along with Cascade audio Deflex pad for behind the door speaks... Do the inside and ouside of the dorrs friend, that always worx for me
williamk10
pssst...
boom boom
Modified by williamk10 at 1:23 AM 12/20/2009
CrankyVersa
That will rock the house bro!!! Nice sub!
williamk10
The price was alright too
$99
Return to “Versa Technical Discussions”
