5Zigen Pro-N1 Help
KaDrifter
is anyone using these wheels on there S-14./ I'm looking at getting these but I don't know what offset they come in or which offset I should buy. Don't do a lot of drifting mostly drag so I was going to run 17x9 on rear and 16x7 on front On the 16 I need a +40 right to clear Z brakes? Plan on running Nismo R-Spec coilovers. Will I need 17 on front as well? Waht offset should i run on rear would like them to be flush rolling fenders is all right any help would be thankfulthanks
barrigas14
16x8 front with a offset of +2717x9 rear with a offset of +35
KaDrifter
they don't make a 16x8 or at least it is not a option on the wheel max web site or could i buy the 8 somewhere else?
barrigas14
wierd...you should just go with the 5Zigen FN01r-c from http://www.hopupracing.com they fit our car perfectly and are cheap and light as well.
