5zigen FN01R-C Pictures
RCA
Hey I am lookin to buy these wheels and I was wonderin if you guys could provide some S14 pictures with 5zigen FN01R-Cs on them, links would be good to.
Pics of S13 will also be cool.
THANKS A million
RCA
:: crickets ::
Guess not...Any members have any pics of their 240s with FN01R-Cs on um?
SayNoToPistons1
Car: 2001 Infiniti QX4, Mazda RX7
Do you want pics of the FN01's on FC's and FD's?
nismofly
Car: 89 Nissan 240SX Hatch
the question should be what size and color are you looking at since im sure theres a few examples of every combination possible out there
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
17x9 +15 front / 17x10 +12 rear
And battleship sunk for laughs!
Modified by ddgsxr504 at 4:27 PM 6/2/2007
nismofly
you have 4 lug front and 5 lug rear?
Fenvy
Car: 2005 350Z Base 6MT
sunken face only comes in 5 lug so that's at least 17x10
ddgsxr504
Okay so you caught my over sight in two different threads now! Sorry
The offset on the fronts are +15
RCA
Any combo of any FCs on any S14.I have 5lug, but if its a pic with 4lug I wont care. Its the same stuff
sr20power
Car: S14 Zenki
Okay...here's 17x8 +25offset & 17x9 +35offset...
another....
last one...
RCA
I like the fronts. They fit pretty well.The rears could of had a lil more agressive offset. They are lacking a lil bit. How did you clear you rear struts with 9' wide and a +38 offset?
I had my 10' +12 offset and they barely cleared...
sr20power
Car: S14 Zenki
Yes i agree with you on the rears...and its with a +35 offset
With the +35offset there is plenty of room, but i'm running Tein He's coilovers. So it might be different with the stock struts....
RCA
W
sr20power wrote:Yes i agree with you on the rears...and its with a +35 offset
I am using Tein SS Coils and I had about 1.5 inches (maybe less) with my 17X10 +12 offset.
I just cant imagine you having much room.
s14_mike
Car: s14 240sx
with the 17x 10 +12 on the s14 could you get away with just a roll and not a pull and run a little negative camber? or do you have to pull the fenders also?
RCA
s14_mike wrote:with the 17x 10 +12 on the s14 could you get away with just a roll and not a pull and run a little negative camber? or do you have to pull the fenders also?
IDK but when I fitted the wheel with out tires it was about 2 inches poppin out. I think its a roll & pull. Plus I want to run 275/40/17 tires so I might even need a 5mm/10mm spacer
s14_mike
Car: s14 240sx
i think for that size tire you would need a roll & pull but, I'm thinking of running a 255/40/17 on the 17x10 so that's why i thought i might not need to pull the fender just roll it.
hsujohn
I had a 17X9 damaged one sold for only $3.75 on ebay
