biosehnsucht »
https://forums.nicoclub.com/biosehnsucht-u13953.html
Wed Feb 20, 2008 4:45 pm
I'm using castrol syntec blend 5w20. It helps... isntead of changing the oil every 1500 miles I'm getting 2000-2500 before the lifters start tapping. Was using 10w40 before, Redline. Yes, this syntec blend is lasting longer than Redline. And since my motor was totally rebuild, I'm sure its not some "old engine leaking from synthetic oil" crap.
I have overcooling problems. Before you say anything, yes my thermostat is fine.
Koyo 53mm rad + the OEM oil cooler setup. If I run my favs all the time, it will never warm up at idle. Leaving them unhooked, I have to be in stop and go traffic for at least 15-20 minutes before it starts to go above normal. With the fans on the AC temp switch, they take 2-3 seconds max to drop from 198*F to 188*F radiator outlet temp, so they'll come on for a few seconds and cut off again for awhile.
I plan to ditch that silly OEM water heat exchanger oil cooler thing, since I think I'm cooling the oil and the rest of the engine too, even with the tstat closed. The heat just gets sucked through the still water.
