lessthanjakejohn wrote:Q45Tech,
Are you saying that we should not always follow what the manufacturer says? That we should figure out what is the best oil to use disregarding the small mpg difference so that we get a longer running engine?
YES!
There are a quite a few threads here on this subject.
All oils that meet MB229.1, MB 229.3 ACEA A3 and other real stringent requirements for volatilty, reistance to shear, temperature stabilty are <at least> 40 weight oils, of one kind or another.
0w-40, 5w-40, 10w-40, 15w-40
OR 50 weights.
A good general thread we had on oils here, icludes a good discussion about oil weights:
http://www.nissaninfiniticlub....il%2A
This started as an argument about drain intervals when I split this off another thread, the resulting discussion includes a lot of myth-busting when it come to oil weights:
Here are listed by name and grade the oils sold domestically that meet some of teh toughest specs:
A short summary of the threads above:
Since manufacturers oil recommendations are influenced to a great extent by the desire to aqueeze the last drop of mpg from the auto rather than durability use a grade thicker than recommended in most situations, especially summer/spring/fall.
(Exception northern winters, stay thin w/ a 0w-30,5w-30, those are the only conditions one should need to run a thin oil)
Please <be sure> to use the links I put in above, where much is explained.
Fred...
