5w-30 synthetic
4johnny
Car: Nissan Rogue 2018
I accidentally used 5w-30 synthetic in my rogue when it calls for 0w-20 synthetic in the manual. Should i drain it?
Thanks,
John
datechboss101
Car: 2016 Nissan Rogue SL -- RIP
2018 Nissan Kicks SR -- RIP
2019 Nissan Rogue SV w/ Prem. Pack
The owners manual also states that if 0W-20 isn't available, you can use 5W-30. So, you should still keep it as it won't hurt the engine at all.
casperfun
Car: 2009 Nissan Rogue SL AWD - Indigo Blue
No, use it for this oci.
Mine is spec for 5w-30, but I used 5w-20 and 0w-30 for a single oci in the past no problem.
I always used synthetic.
You most likely get less fuel efficiency but more wear protection with the -30.
The 0w would benefit in the cold, but we have 100 degree weather in some parts, so I wouldn’t be worried with that aspect either.
But if your really ocd with your oci, do what makes you sleep better at night. :dance
Andy2105
Car: 2008 Rogue SL AWD
2018 Murano Platinum AWD
I wouldn't dump it, just don't do it again.
Return to “Rogue Forum”
