5u5p3n510n setup
xxxboostinxxx
Car: 1990 240sx
I am new 240 owner. I enjoy driving my 1990 240sx but the suspension is not what I want it to be. I like to get sidewayz but this stock suspension is not cutting it out. I am looking to get a new suspension for around $1000.00. I do not drift professionally and do not entend to, but I do like to get sideways whenever I can. I need something that can give me a little more control. I just need something that is good enough for entry level drifting.
What kind of suspension do you guys have in your cars?
My friends have suggested getting Megan, Tokico Blues, Godspeed, or gas shocks.
Let me know what your set up is and what you guys would suggest.
Thanks
LayNLow240
Car: 92 240 coupe
Stance or bust.
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
check out the suspension forum and the drifting forum and see what other people are running. nico members are pretty much using everything, so see what everyone else has to say about their own setup and decide from there.
streetbikestunta420
Car: nissan 240sx/red top sr20det
i got some tien coilovers, cusco pillow ball tension rods, and some new nissan lower control armshavent really gotten too sideways yet..still learning but it handles exstremly well especially down some mou8ntain runs ha
Chris28
Car: 92 s13 KA-T
Powered by Max has some pretty sweet stuff, looks really beefy. I know a few members are running them with no complaints. If you have $1000 to spend then please don't get megan's. They are fine if you are on a budget but with $1000 you can get a much nicer/reputable coilover.
xxxboostinxxx
Car: 1990 240sx
thanks for the tips. I will check out the suspension forum too. still new to the site (found the search button) comes in handy
MastaYu
Car: 92 Nissan 240SX SE HB
Welcome
ashibah83
Car: 93 SUPA BLACK COUPE
are you going to be tracking the car???
if your not then i see no need for you to need coilovers, unless you want to slam the car, just go with some KYB AGX's and a good drop spring and a master bushing kit and you should be ok thats probably near 800 all together
musashin
Car: 1993 S13 hatch
If you want a drift-purposed coilover for $1000, go for Powered By Max. IIRC, they're 12kg/10kg springs, which will give a very stiff ride, maybe not comfortable enough fr a DD but very good for drifting. If you want a good street coilover, might i recommend Endura-Tech. Good valving, nice adjustment range, fit your budget perfectly. 7kg/5kg springs for a firm yet more streetable ride.
smocan
musashin wrote:If you want a drift-purposed coilover for $1000, go for Powered By Max. IIRC, they're 12kg/10kg springs, which will give a very stiff ride, maybe not comfortable enough fr a DD but very good for drifting. If you want a good street coilover, might i recommend Endura-Tech. Good valving, nice adjustment range, fit your budget perfectly. 7kg/5kg springs for a firm yet more streetable ride.
+1 on endura-tech
adrianfromthecastle
Car: 1992 Nissan 240sx
I wouldn't recommend stiff spring rated coilovers (anything as stiff as 10/8kg or stiffer) as entry level or for beginners... I'd start out softer (~8/6kg), then work your way up if you still think the given spring rates don't do it for you. Trust me, dailying 10/8kg or 12/10kg spring rated coilovers are not fun for a daily driver, and may be unsafe on the highway or bumpy side roads
xxxboostinxxx wrote:My friends have suggested getting Megan, Tokico Blues, Godspeed, or gas shocks.
KTS, Stance, Endura Tech, and a handfull more are all great choices for entry level type coilovers that are both bearable for daily use as well as weekend slider.
