gawdzilla wrote:sometimes i get a grind going into 5th too. just gotta take it a bit easier. high rpm shifts into 5th you're already 120-135 mphish, no?
i'd consider a rebuild necessary if it was like 2nd,3rd gears... but 5th is hardly high rpm'ed from 4th.
what fluid are you using? maybe try something to help the syncros a bit
QFT.
Yea honestly if it is just 5th gear I wouldn't worry too much. Hardly ever shifted into at high RPM.
Also make sure your clutch is fully disengaging, and try switching out to a different fluid (I've had good luck with the GM/Pennzoil Syncoromesh, many others love the Redline stuff).
