I repeat, factory fuel cutoff is at 5.5 this is a well known fact. Also, I am not getting my mph spec from my car, but from the actuall factory number. I certainly wouldn't be telling you what the rev cut ocurrs at in my car, because I know that the stock tach is very inaccurate, as well as the speedo. When you say that your speedo is "off by a factor of .4mph/1k rpm", this may be true, but realize that when speedometers stop being as accurate, thei'r reading is often not that linear. My last 240sx read high at low speeds, and low at high speeds. Im gonna stop posting in this thread because it's a waste of time. You aren't gonna want to go faster than 115, unless you have a good suspension setup, more power, and better brakes. My car feels very stable and controllable at over 100, but that is because it has coilovers, subframe spacers, 16" wheels with stiff, high speed rated tires, among other things. I really don't think anyone in a stock 240 should be hitting those speeds. Big floppy tires and suspension could get you in trouble fast.rsmithdrift wrote:I cut my fuel cut off and disconected the 4th and 5th gear sensors at my transmission. So I have gotten to 6.2k rpm (hwy 111 going down Signal Mtn). If my speedo went that far it would be 149mph. But my speedo is off by a factor of .4mph/1k rpm. So By using gear ratio and tire size and whatnot. that is actually 146.8 mph give or take due to tire warping.
On flat ground my car can go 115 in 4th at 6k or something. In fifth I am only at just under 5k. That is were my fuel cut off USED TO hit.
Naed240sx: You have the wrong sized tires on your car, or your speedo is WAY off. You are going 130 at 5.5k rpm if you have 205/60r15's on your car. End of story.
112 at 5.5k is total BS!!! If that were true you would be at 4k at 75mph. It is well noted that 240's hit 70-75 at 3k rpm. You are very wrong.
