Do you have any other details on how the ECU would have a different map without a speed signal? My SR runs the same as it did before and the idle sits dead on. The only thing is i can go way over 118 now.pampadori wrote:the ecu doesn't see a speed signal, so the maps it chooses are different then if you left it hooked up. idle will suffer slightly on most cars.Shaun
i think it runs better with it cut, or at least mine did, comes down to a perfect idle when i shift to neutral or just stop periodgot2b240 wrote:the ecu does, it reads the speed from that yellow green wire, then if you disconnect it, you kill the signal and the idle drops below normal ("dips") when you come to a stop or you are rolling and put it into neutral.
