5th Gear Rev-limiter on Redtop?
DriftS14
According to many sources, eliminating the speed cut is as simple as cutting the speed sensor wire and unplugging the 4th and 5th gear transmission sensors. The latter because there is also a 5500 RPM rev limiter in those gears. Back when I had my KA, I cut the speed sensor wire, only to encounter this 5500 RPM rev limiter. Even sitting at a dead stop, if I put the transmission in 5th and revved it up, the revs would cut at 5500. Now, while in SR land, I've been pondering the same thing. Difference, when I put the transmission in 5th at a dead stop, there is no rev limit at 5500 RPM. It revs right up to 7000 + like its supposed to. Does this mean that All I need to do is cut the speed signal at the ECU and call it good, or am I in for a surprise this time too? Thanks guys.
http://rap.midco.net/jprosper/0-118mph.wmv
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
My KA had no speed/rev limit (only redline), and when I swapped my SR I still had no speed/rev limit (*also only redline). I also drive a 95 SE as you drive a 95.
dj_lennon_franz
Car: 1992 240sx
i had my car WAY past 180km today (needle was down by the odometer thing) and still had a good chunk of 5th to go when i shifted into (this was blowing the doors off a brand new copper 350z while i was carrying like 5 barrels of C16 in my car lol) guy never knew what pull 89372984 bus lengths on him lol...but ne ways yah i went way past the speedos 180kmh...i really wanna know where the speed sensor kicks in
240SXer
Car: 1995 240sx SE (2jz powered)
Mine does at about 136mph it his the 5th limitor
DriftS14
240SXer wrote:Mine does at about 136mph it his the 5th limitor
I wish mine did at least that. 115 is my max. It'll hit in 4th and 5th. It sucks. But I'm pretty sure I don't have a 5th gear limiter. I have an E5 ECU, I wonder if that has anything to do with it.
240SXer
Ya, I can do about 123 in 4th.
DriftS14
Everytime I g-tech my car the speed limiter hits less than a second after finishing the 1/4 mi. I love that little machine. Or device I should say.
240SXer
I haven't tried reving it up in 5th to see what it does. I'm pretty sure it's my 5th gear limitor that's slowing me down beause it's so high (136) I remember my KA dropped at 118, my 91 KA stops at about 110 or somthing.
Zadok
Car: '99 30th Aniversary Legacy L
My Ka turbo was 118mph and it sucked.Imagine having a car that will do 150mph and be stuck at 120mph.A JWT ECU fixed that, and made things safe!Now, my SR topped out somewhere around the 130's.I was racing a bike and the speedo was barried awhile before it hit!I guess i'm going to have to snip that wire too, b\c the stage 2 upgrade is a long time off!
DriftS14
I made a vid so guys could see my dilemna.
DriftS14
Hey 240SXer, have you ever seen your 0-136mph video at 3 times the speed? Your car turns into a crotch rocket! lol :)
240SXer
hehe.. I bet.. It pulls pretty hard to 135 doesn't it? In my KA s13 today while I was at a light I put it into 5th and I revved it up, it bounced at like 5500rpm.. I did it in 4th and it went to the normal 7200rpm
Krnmackmattsta
hey drift s14...this is kinda off topic but how much rwhp u running? I dunno if im just not educated, but it seems like ur acceleration is kinda slow. The reason i say this is because my friend's wrx (intake and bov) goes 5-60 way quicker than your car (or maybe im imagining things). Does your car pull harder than i'm describing and am i BSing myself?
DriftS14
I did baby it off the line, but other than that I tried my best. When I launch it hard, the g-tech says I do it in 5.3 sec. I have never dynoed my car, I have no idea how much hp I'm running. I'm still running stock injectors, so I only run 9 PSI. It feels faster now than with the T25 at 14 psi, but with the T25 I beat 2 different STi's. But I can see what your talking about. It doesn't seem that fast at all.
DriftS14
240SXer wrote:hehe.. I bet.. It pulls pretty hard to 135 doesn't it? In my KA s13 today while I was at a light I put it into 5th and I revved it up, it bounced at like 5500rpm.. I did it in 4th and it went to the normal 7200rpm
That's what my KA S14 had done. It doesn't do it now, but as you can see by the vid, 118 is still my max.
