costa_rican13 wrote:well the stock ecu has a fuel cut. so you wouldnt want to even try to wire the sensors for the limiter. if anything get a bee R* limiter. they work i've had one before. easy to wire up and have three knobs to adjust the limiter, redline cut, and how agressive of a cut you want(like 2-3 feet flames coming out the exhaust!) and you can wire the launch cut to the e brake or the clutch whatever you like. or just get an ecu that has the cut programable. i think nistune has that option.
Oh I though the stock ECU was ignition cut limiter, I don't really know the difference but I heard the fuel cut limiter is a bad idea.
I guess that idea is out the window. End of topic
I heard a lot about Bee-R limiters, but they cost a lot money. It's not like I'm launching all the time. I thought the stock one would be a cheap solution.
And I wanted to try this one from e-bay just for fun and experience.
http://www.ebay.ca/itm/110359750284?ssP ... 1438.l2649
Doesn't seem like there is much that can go wrong. There are only few wires. should be easier than wiring an S-AFC which I've wired up with no problems
Any advice?
