hi guys and girls
first of all i would like to say hi, im a new member.
ok i should say who i am and what i got. i live in australia and own a VL Commodore which had the rb30e and et std from factory, but my motor died a few years ago so i replaced it with the rb25de (non turbo) motor runs great and i had it behind my std auto trans which had o/d. than the box died (did have 240,000 km on it) i then purched a 5 speed auto noted bye the extra housing on the rear near the extension housing.
but i have a delima, the box came with a loom, up to some plugs 5 incuding the spedo which was in the engine loom on the motor the box came from.
i was lead to believe that the std 4 speed tcm would do this box also so i got one, but the about 10inches of wiring.
the box is mounted in vehicle and works, put it in gear and the output shaft rotates etc. but im stuffed if i know how to wire it up.
the question is does any one have a digram i could use. i do have one set of digrams but suspect its for the 4speed box
also does anyone know the part no. of the box or anything im pritty much stumped with this setup.
thank you for reading......
