: NISTECH wrote:no would not effect drivability. if you can get it up on jack stands with the rear wheels lifted off the ground you could crawl underneath and spin the drive shaft by hand while giving a little force up ward and downward. see if it rubs. you can usually see where the dust shield is extreamly close to the shafts sheild.
If the dust shield is removed would anything negative result?
: drjohn wrote:Could be a intermittent center countershaft bearing beginning to fail. Release bearings tend to make noise when the clutch is pushed in. The center countershaft bearing takes a very large amount of load and the bearing cage comes apart. Sometimes when you drain the gear box you find this cage stuck to the drain magnet.
The noise happens when the clutch is out also, but only when my foot is lightly on the accelerator or completely off of it.
: djtomr941 wrote:Have you had any work done to your cv axles lately??
Anything like that?
Also your CV Axle seals could be bad, lets hope not. Mine went bad and all the transmission fluid leaked out and I went to Miami about a 4 hour drive and it started making this metal grinding noise and it got worse. If I were you I would check the transmission Fluid Level. It is 80/90 gear oil I believe and you can buy it at any Auto Place. You have to Jacke it up and there is a plug towards the front of the vehice. Pop that out and see what is in there. Or just pull the axle out and see if it has fluid in there. If it does then you are safe.
I havent done anything with the CV Axle. I also dont notice any leakage of fluids. I will check the transmission fluid level if it isnt the dust shield.
Thanks for the info everyone, i'll post up if i find anything new.
