5spd parts
Harman850T5
Car: 2003 350z
Ok so far this is what I have so far.
not pictured is the slave cylinder which is already on the transmission, pressure plate bolts and m/t bolts. I plan on cutting the auto brake pedal too.
I'm ordering an exedy clutch kit after vacation.
I'm going to the dealer sometime this week to pick up a dust boot for the shifter, the little bushing that goes on the bottom end of the shifter, and a reverse switch for the transmission(all I got was the transmission and the fork when I bought it, but for $35 I'm not complaining)
With the shifter, it pulls out and gets stopped by the plate holding it in. Is there something else I should buy to keep it from pulling out?Here are some pics in case it helps
From what I've read the only sensor you need is the reverse right? So could I just get some bolts to cap off where the other sensors go so I don't waste money buying those too? Other than the shift boot and knob, is there anything else you guys can think of that I still need?
Thank you for your help
And to Jspec, thanks for your input on the battery tray removal, sorry I didn't see your post until now.
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
be sure to get a new front seal. the shifter, there is a little ring that keeps it in place if i recall
biggie
That metal plate on top that bolts to the ring of the transmission is what stops it from pulling out, that's it.
240vert93
I'm not sure if you need it or not but on my clutch line there was a box that had a hose loop on it and an input and output line alone with a bleed valve. It bolts directly across from the slave cylinder onto the car (my convertible had pre-drilled and tapped holes so it bolted up easily). Anyways its the only thing I dont see there that I had.
Harman850T5
Car: 2003 350z
Thank you for the replies, I'll have to check into the bleed valve thing. Hopefully I'll be able to go to Nissan Monday morning to get the parts. I forgot I was doing the RMS too.
