5spd oil change questions ('91 2wd D21 SE)
UFS207
Car: 1991 Nissan Hardbody
I got a '91 2wd Hardbody SE (V6/5spd) I need to do a transmission oil change on. Does the TSB about overfilling the oil by a couple pints on 4x4 V6 models apply to me? As far as I can tell the 2wd V6 equipped hardbodies have the same transmission as the V6 4x4's (FS5R30A), correct?
Also, had a really hard time finding GL-4 rated oil locally. I bought some Royal Purple 75-90W GL-5 stuff that specifically states on the label that it's safe to use in transmissions with yellow metals. Is it OK to use it?
Any help appreciated, thanks!
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
No GL5 products should be used. Redline Oils makes a GL4 that will work. It won't hurt to overfill a little bit. But yeh even if the oil says it's safe for yellow metals it is not, GL4 only!!
UFS207
Does the TSB apply to the 2wd V6's 5spd though? I can't find a straight answer on the web. Guess I'll just measure what comes out and put the same amount (plus a 1/4 quart or so) back in.
Noted on the GL4 only. Can I use this GL5 stuff in the diff?
Rev_D21
I always overfill mine slightly, just a habit. It won't hurt them any. And yes GL5 in the rear diff.
