5spd conversion in S14 and a couple of other questions
SilverSX95
Car: Cars, Car tuning, and computers
1. Will the brake pedal and clutch pedal out of an S13 fit on and S14 along with the manual transmission?
The lines look different so I think I'd have to get the real S14 ones.
Over here there are a bunch of S13 that are manual so that' s why I'm windering if it will fit on a S14. Thanks.
Matt
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
ok, i've looked into the s13 pedals some since im getting ready to swap 5spd too, and i dont think they'll work, but ive heard 80/20 mixed review (80%no/20%yes) ...my recommendation (wat ill be doing) is cutting down the automatic brake pedal to size... that way u dont have to drop the steering column if your good and u only have to add one pedal. it'll make things easier. As for the lines, u need S14 lines.
-Dan
SilverSX95
Crap, thanks though.
Matt
proimport17
Car: motocross, baseball
The s13 petals wont work. The clutch is completely the wrong bend and the accel petal will be to high. Cutting the brake petal is the easiest way out. I did it the hard way and swapped the assembly but if i did it again i would just cut the petal. Buy the clutch hard line from Nissan. It is bent correctly and only cost about 25 dollars.
