UncleBen »
https://forums.nicoclub.com/uncleben-u259.html
Sun Jul 27, 2003 9:25 am
Well the ole 2slowty is a 5spd now. I love it so much! But there are problems. Lets see, where should I start. I'll start small....The brake pedal I got from a 5spd 240 didnt' fit (from an s13, it shoulda fit I thought), so the guy that did the swap just trimmed my auto pedal down. No biggie, but, it is the first of many. Next, my windows and sunroof dont work at all now, when before I left the car with the guy to do the swap, they worked fine. I think they are unplugged somewhere, somehow, for some reason. Next, The transmission I got is broke, so I have a friends (cnichols on the boards) transmission in my car (he had an extra one). But I think my transmission can be fixed rather easily, because of a type of fork thing that could be broke inside the transmission. So the guy is gonna open the transmission up for 40 bucks and look and see. If it is just the fork thing, then he can fix it, and I can put that transmission in my car and give Chris' back to him. Next, the speed sensor that I got with my transmission doesn't fit this one, and the one with this one is broken. So I have no speedo, therefore the mileage isn't going up. So if I get my transmission fixed though, I will get the speedo and odometer back. Last, the driveshaft is too long. It works, but The end of the shaft that goes into the input part of the end of the transmission, has a piece that rubs, which will make one of two things happen. One, it keeps rubbing, making a whining noise, and rubs until it just wheres down and there will be no more noise. Two, it breaks the rear seal of the transmission, causing transmission fluid leak.
I know that was very long, but there were lots of problems (well, still are), so I figured I'd share. Its good to be back on NICO though, after a week not being on. I was out of town, so it is good to be back.
