5lug swap on a 240sx
impactsus
Car: things with wheels
Is there a 5 lug hub that will swap to the 89-93 240sx. The nissan dealer said the 95 and up hub might fit the older rearend,but he wasn't sure. I'd have to check the bearing part # to see if there was a common bearing . Has anyone done this swap? Does changing to a 300zx hubs add width to the rear?
humpy012
Car: Mark VIII
sport compact car did it, you could check http://www.sportcompactcarweb.com
Got_Nissan?
Got my four hubs for 40 bucks hehe...:D
God bless the junkyard
impactsus
Which hubs did you get? The 300zx or the 95 240sx se hubs?
nomuken
http://www.sportcompactcarweb.....html
from the article:"Finding five-lug hubs in the junkyard is nearly impossible. We eventually gave up and bought new hubs (Nissan part number 40200-0V010, $120 each)" :jawdrop: another option is Attain in Japanhttp://www.nissanperformancema...40sx/
Got_Nissan?
96 240sx se is what i got em off.I also got the sway bar off of it, and other little stuff.I got unbeleivably lucky.
It looks like it's pretty low miles. Somebody messed it up bad though. Drove it into a light post or somethin. The reinforcement inside the bumper is bent almost 90 degrees.
Too bad cause i needed a better hood and fenders. It's my color too, :mad:
