I live in Vancouver so rust is too much of an issue, but I know what your saying about the rust on the 4runner's tailgate and rear bumper and the Pathfinder/QX4.Buzzman wrote:I bought my 2002 pathfinder in 2003. It was a low mileage lease return.
I would buy it again in a heartbeat.
The main concern now is rust. I live in Canada in a snow/salt environment.
Most, if not all, of the older Pathfinders here are rust buckets. There are lots of them in my local junkyard.
Fortunately, I oil sprayed and undercoated mine almost yearly.
Even with that, rust is eating away at my rear wheel wells. I also had to repair the rust in the roof at the top of the windshield.
If you live in the southern U.S. I would definitely buy one.
If you're up North, buyer beware. Look for a 2002-2004. The lower the mileage the better of course.
Same holds true of the other makes you mentioned. I've seen a few 4-runners up here with massive rust issues as well.
From what I have read the repairs you have listed seem to be fairly common, correct me if I am wrong, but the front axel and ball joints sound expensive. I was told that on most trucks this age you will want to make sure the ball joints were taken care of - this is usually part of regular service (a milestone around 160k I think)saskapath wrote:I picked up a 2002 Pathy this spring for that price. The issues I've had might give you some things to look at.
1-Ball joints were totally worn out
2-Driver side front axle needed to be replaced
3-AC compressor was toast
4-BOSE audio system was non funtional
5-Driver side O2 sensor was defective
6-Both cats are shot, see # 7
7-Oil consumption is through the roof, 1 litre in 600 miles
I've taken care of everything but 6 and 7. There seems to be a possibility that the oil is getting sucked into the intake via the PCV circuit due to a plugged baffle drain in the passenger side valve cover. Investigating that is next on my list. No point dealing with the cats until the oil consumption is reduced.
A couple of other things to look at. Mine is a manual transmission so I wasn't concerned about this one. There are a set of butterfly valves in the intake system called Power Control valves. The screws used to hold the plates to the shaft missed getting threadlocker at the factory and had tended to vibrate loose and then ingested causing damage. The other is a recall to check for corrosion in the strut housings which can be extreme. It hadn't been done on my but fortunately there was only minimal corrosion.
All in all it's a solid vehicle but I'll be happier with it when the oil issue is solved. I get about 17 MPG (imperial) city and 22-23 on the highway.
Good luck!
Front axle and ball joints are not too bad. The parts are relatively inexpensive , and I was able to do it as a DIY job. The tricky part is getting the ball joints out, but with a little inspiration and a loaner tool from Autozone, it wasn't too bad. Shouldn't be too many labor hours if you have a professional do it.skier14 wrote:correct me if I am wrong, but the front axel and ball joints sound expensive
