tollboothwilley »
https://forums.nicoclub.com/tollboothwilley-u74535.html
Tue Feb 23, 2010 2:44 pm
I just installed (with the help of a friend) the Transgo Shift Kit. Installed one on his car (2006 Coupe) and right after installed one on my 2003 Sedan.
I can now say that I have installed both versions of the VB
I'll post up a video soon. I love fast shifts.
For those of you who have a 5AT, this is about 10-20x better than the ground wires. Its really no comparison.
They were on sale at Summit for $230 + shipping. You should go out and get one!!
I might be able to help install as well.
For some pictures of what it is...Most of these pictures are when doing the 2006 VB (TCU inside transmission) 2003-2004 will look a little different.
Get the transmission oil pan off...this is what you see (20 bolts and 2 clips come off to get the pan off)You'll get about 5 qt out when you drain. Another qt or so is in the pan still.
Keep it all organized. I didnt have enough baggies, but used those for the first couple letters of bolts. Label A - L
Remove the 12 bolts holding the VB in - 5 A, 6 B, and 1 C. There are also 4 clips you need to remove. Depending on what transmission you have (TCU in/out) they are all 4 visible OR 2 of them are on the top of the VB and you have to lower it some to release those.When you remove the last bolt or two holding the VB in, you'll start draining out the torque converter. You'll get another 2 qt or so from there.
VB Out - BottomBottom side of the VB - here you can see the filter. Remove 14 bolts holding filter on. 3-E, 8 -A, 3-DThis pic is the 2003-2004 model
Remove the 6 bolts holding the manual shifter onto the VB. 1-G, 1-F, 2-H, 2-CRemove manual VB and pay attention to where the check ball and springs are.Remove the 14 bolts holding the lower to the upper VB. 8-H, 5-C, 1-A
Remove the 5 bolts holding top to bottom, making sure to remove the bolt labeled A last. 1-A, 2-I, 2-J (J bolts are reinstalled first as alignment bolts during reassembly)
The VB kit is too hard to show the detail of what happens... You change out 3 valves and add check balls and springs on the left side. On the right side you change/add springs in 4 locations.
Valves are hard to remove on the left side. Springs are very hard to keep inside and reinstall the retainers on the right side.
With the 4 drill bits provided you enlargen 7 holes in the seperator plate.
Pay close attention to the location of all check balls and the filters (different amount/locations depending on which VB version it is) during reassembly.
Follow the transgo instructions carefully and make sure you double check everything.
Reassemble opposite of assembly. During assembly I made sure to clean each surface of the VB that was possible to clean.
