Year: 1990
Make: Porsche
Model 944 S2
Engine: 3.0L I-4 DOHC
DIversions from stock:
Engine:
Cone Filter in nose panel
Catalytic Converter Removed
Planned for winter: 2.5" cat back exhuast
Smaller throttle pulley
new injectors/sparkplugs/distributor
Suspension:
350ft/lbs Hypercoil Front Springs on adjustible perches
Koni 2-way Dampers (linear adjustment)
28mm Weltmeister Torsion bars
28mm Weltmeister Front sway bar w/ adjustible links
22mm Welmeister rear sway bar w/ adjustible links
Paragon-products ball-joint kit
993 Turbo cup type 1 rims w/ Bridgestone potenza RE730 tires (225/255 F/R)
Planned for winter: Racers edge camber plates (not much left there to do)
Brakes:
Hawk "PC" ceramic Pads
Lindsey Racing Stainless Steel Brake lines
Paragon Titanuim pad shims
ATE "blue" high-temp brake fluid
Transmission:
Planned: Short-throw rear linkage (decreases shifter movement without shorting the shifter itself)
Turboswap w/LSD
Interior:
Nardi gara steering wheel w/ momo hub adapter
"only944" shifter update
G-force Harness
Camber-truss Harness bar
Recaro SPG seat (drivers only)
Planned: Rollbar
