:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Tue Jul 19, 2005 2:27 am
We're not worried about the S-AFC correction throwing the timing map off...that's a whole separate concern.
I'm talking STRICTLY about trying to make +250rwhp on a stock ECU, where it gives almost 10 degrees advance under full load and high RPM.
For example, for ~300rwhp, you'd need about 12-13psi from a decent turbo, and *maybe* 19-20 degrees total timing at WOT.
With a stock ECU, you'd be getting AT LEAST 28 degrees total, and a you'll detonate for sure. Goodbye KA.
...then factor in the S-AF correction and how it puts the timing curve in the wrong place (cutting the airflow voltage that the ECU sees will mean it senses MUCH less load, and give WAY too much advance = boom).
- Brian
