That's quite possible. I will get dyno graphs and post pics nonetheless.nsrZ32 wrote:Sounds like the update will be when it blows up.
I've seen people make a lot of power on stock internals on the 300ZX. Only real weak point (beyond like 550 or so HP) is the pistons.nab911 wrote:Judging from what you desribed, sounds like the dyno chart has a huge power curve up high and is **** for anything but dyno numbers... i dont know much about the vg but not many motors can take above16-18psi on stock internals. (unless you have an evo that is 28lbs stock.. wtf)
FALSE. Stock internals can take a beating. Many people have run close to 600whp with zero problems over many years. Where are you guys getting all your info???freakonaleash1187 wrote:so the internals have not been touched at all?! anything over 500hp will be pushing the stock internals almost over their limit. do you have any idea of what kind of turbo he is using? "stage 3" describes nothing. if they reach 550wph, i would be amazed.
I am actually in western MD, Hagerstown to be exact. The Z was being worked on in a shop here in town. It’s on the road and running fine from what I gather. However, I have not had a chance to drive it since it first got out of the shop . I'll post some more updates if anything else develops (I think he was still shooting for more boost and chance to run at the drag strip this summer).Nick240sx wrote:s13satch......you wouldnt happen to be in southeastern pa because i was talking to some guys dad who has a 240 and how he has a twin turbo motor being put in his Z with the same expected HP numbers and that the car was taking a long time.....
Not worth the price in my opinion. Although it is a nice kit, the PE1420 kit is a far better deal. The GReddy kit can't make that much to the wheels and you'd better have it tuned well if you're looking for numbers close to that. The JWT500 turbos are not much larger than stock and won't make 500whp..more like 500 to the crank.partymonster 975 wrote:I want to know how this will turn out at the end. I hear the Greddy kit can take 700hp. If I was running that I'd probably go with JWT 500 turbos. Does anyone have any knowledge of the Greddy kit? Is it any good, I've seen it go for about $5000. Worth it?....For a 500ish HP goal that is?
Those would be more in your ballpark for power output and they spool up quick too.partymonster 975 wrote:So you know anything about the JWT sport 530 BB turbos? The Greddy kit is to much for me. I have a 500hp goal in mind, anything to much over that is just more then i'll really need.
Close enough..if you're just looking to stake a claim then it isn't going to happen. But if you're looking for a quick spooling set of turbines that'll get you close to there..then those are your turbos. I'm personally using GT28R's, but I'm looking at 600whp+ but still decently quick spool. I'm all about response and I wanted more power, but keep a level of responsiveness which I'll definately have with the upgraded cams and the fact that the RB26 has ITB's.partymonster 975 wrote:Do you know if they can put 500 to the wheels?
The 550cc injectors should be okay, but they'll be working on the high end of their duty cycle..which is the reason we recommend higher output injectors...to be on the safe side.partymonster 975 wrote:Will 555cc injector be enough? I hear that they don't flow enough fuel and 740cc injectors should be used? This is for the JWT 530 turbos.BTW: thanks WidebodyZ, you've helped me out a lot.
