550+ HP S14 build
Alwaysoverbuilding
Car: 1998 silver moss s14
So a friend of mine got his sr two years ago and was planning a build, but the guy who was going to build it flaked out. I found out about this a few months ago and the build is back on but it has morphed from an average sr build to a monster...
So heres the plan-
Mazworks 90mm sleeved blockMazworks 91mm stroker kitMazworks Stage 3 P&P headMazworks Intake ManifoldMazworks top-mount Turbo ManifoldJun Stage 3 camsGreddy Rocker StoppersRC 1600cc InjectorsGarrett GT3788rGreddy r33 fmicwater/meth injectionApexi power fcvg transMazworks Carbon fiber driveshaftDiff.??????? TBD
This will be 2.34l displ. when done and bullet proof
we are also doing all suspension and brake upgrades first10,000hp is fun until you have to stop!!!
Full SPL Suspension, r32 calipers with 300zx rotors for now 350z rotors wont clear stock wheel.
This will not be an overnight build this much money and time isn't going to be ruined due to rushing... will post pics as we progress.
Seanzyyy
Car: 1990 240sx se coupe
wow...i'll be watching this thread
fabrisuzu
Car: 1992 240 coupe w/sr
hell of a first post! This will be amazing when done, keep us updated!
sean@z1
Car: 1993 240sx
Post up pictures ASAP
Justin35ll
Car: s13 coupe sr20det
Sounds like a nice build
Alwaysoverbuilding
Ok so we have the SPL Tension rods, Outer and Inner Tie Rod Ends, Nismo Power Brace, and Front R32 Brakes installed. The SPL lower control arm, and whiteline sway bar have been ordered and will be here within the week pics will be up soon oh this will be a daily driver.
Alwaysoverbuilding
The calipers painted
Alwaysoverbuilding
This is the original engine he planned to build(300-350hp). we cleaned it up and painted it, but the we decided sleeved 2.34l monster so its extra now. maybe install it into a 65 beetle
pauliedrft
Car: 91 240sx
nice throw it in a datsun 510 i didnt even know you could go stroker to a 2.34 ltr . how much hp can that thing handle
Alwaysoverbuilding
Mazworks is running this same block/head combo in their 1600hp drag car but that is not quite reliable enough for a daily driver-- street maybe reliable no, but it is capable of 60+ psi and 10000 rpm we are hoping for 850ish on race gas water/meth and prayers at the dyno, 550 to 650 on street trim. engine will cost us about 17500 but it will be worth it...
Sil80315
Car: 1991 Nissan 240sx
Sounds like a bunch of window shoppers to me. There is no reason to spend 17k on a motor to make 600+hp Unless its going to be a full drag car. This car will be completely pointless if its a daily driver or just something to drive on the street.
Mazwork is running a fully built VVE head, not s14 head. so you don't have the same block/head combo.
Either way. If you go ahead and waste the money on the build then COOL post up your pics its just kinda weird that you have 4 posts on nico and right away you post talking about how sick of an sr your building.
Good luck.
SuicidnS13
Car: SC300 2jz, 93 Vert (RB), AcuraTL
Also its not even his own build. Build threads should not even be started unless it shows progress from the beginning! Pics from start to end! Not pics of a stock sr20 block and some 50.00 z32 calipers on a freshly turned oem rotor. I counted a total of about 800.00 in parts photographed.
Sil80315
Yeah at least show us that you torn down the motor and already have some of the parts sitting on your bed room floor. I bet this thread stops here or it will turn into "Im serious, me and my best friend are going to put our money together and build this motor" blah blah. Well unless you guys work for Microsoft I don't see this motor being built anytime this year or the next
WE DEMAND MORE PICTURES
