Davezilla »
https://forums.nicoclub.com/davezilla-u195464.html
Mon Nov 19, 2012 12:49 pm
That's a good link for the driveshaft problems found in lifted 4x4's since the pinion angle can become excessive really easily when raising the suspension.
For the vibration problem you're talking about, it could be a worn u joint, or wheel bearing, or if it happens at certain speeds then goes away it could be a bad tire. But from the looks of the pics you posted, that could very well be your problem right there...
