71-521 »
https://forums.nicoclub.com/71-521-u110104.html
Wed Dec 31, 1969 5:00 pm
here's a excerpt from his post on ebay:
Front valance Left and right rocker panels Radiator Core support Left and Right Bed sides Tailgate Tail lights, both sides 62652-20601 Frt. Bumper (On Truck) Plastic surround for cluster new but out of bag (On Truck) 26350-20616 Wiper motor (On Truck) 23100-16715 Alternator (On Truck) Head liner new out of bag 96400-B0100 & 96401-B0100 left and right sun visors 30610-B0301 Hand Brake Assy 22162-25700 Dist cap 25410-20500 Fuse box 2 (1, On truck) 25230-20500 Relay 27135-B0100 Heater control 27145-14800 Heater control 80605-B3000 L Outer door handle 80606-B3000 R Outer door handle (On Truck) 22145-89900 Points 4 78120-26261 Rear mud flap 2 80672-32200 Inside door opening handle 2 26372-14812 wiper pivot R 26371-20610 wiper pivot L 22450-14929 Plug wires Parking Brake front cable new missing tag 26385-14911 Wiper arms 80502-10602 R Door latch 80503-10602 L Door latch 80691-26261 Inside door pull 2 30502 -14601 Throw out brg. 62800-14800 Hood emblem 16370-14601 carb linkage 25260-B0104 Wiper switch Headlight switch Directional switch Fuel tank sending unit 80571-21000 door striker 80286-14900 Vent window glass 80241-B3000 Vent window seal 80338-14801 Door track glass felt Speedo cable new out of box Windshield gasket new in bag missing label 93417-20500 tailgate chains 2 sets (1 set on truck) 66105 & 66106-14830 left and right A post panels outside to the right and left of glass 93431-14800 tailgate handles 2 17229-14800 Gas filler hose 93360-B0100 Gas door 24014-20501 Rear wiring harness 24013-20600 Cab wiring harness 93588&93589-14900 Tail lamp mounting panels 80337-14800 Seal 76800-B3000 R Door seal 76801-B3000 L Door seal 27061-11400 Heater ducts (paper tube) 27062-B0100 Heater hose 27061-B0100 Heater hose 27067-10800 Heater hose 99990-00706 Lil Hustler wood shift knob fan switch new out of box 25410-04100 dome light Fire wall seal for steering column new out of bag Upper steering column bush new out of bag 48054-20500 steering column mount 40023-30000 lock pin for king pin Window crank new out of box 46281-20500 brake line 46290-B3000 brake line 46210-B2000 brake hose 25150-B2000 Ignition switch 64821-32200 plug 10 17543-10600 grommet 2 32273-36900 bearing rear 63147-10601 fender seal 32272-H7300 transmission bearing 00911-74510 nut 10 20675-B0100 brkt. 20137-27160 bush 3 36441-32200 equalizer 54613-14900 sway bar bush 2 62662-04100 bumper bolt 4 95156-14801 bush 4 63145-14800 rubber 2 20136-27160 bush 3 13010-02710 cam end plate 13002-13200 cam bearings 00344-60810 screw 4 46240-B0100 brake line Throttle cable new missing tag 32264-14800 transmission bearing 4 80570-E6000 striker 36433-14800 rod 2 20602-S0600 exh nuts 10 27363-04100 grommet 2 25230-13200 relay 13202-20600 exh valve 4 Sway bar links 2 new part# unreadable 24422-08500 battery rod 95147-14800 body mount washer Cab mounts 4 no tag Idler arm new no tag 00334-01210 screws 10 64803-18000 clip 10 36405-14800 cable B6361-89900 wiper refills 80285-10600 seal 2 12316-30000 key crank shaft 46310-B3000 brake line 22145-89994 points 2 22102-00801 condensor 2 41130-14800 connector 14056-25603 hose 14056-14601 hose 14056-14600 hose 36402-14900 cable 32809-21100 shift rod Front wheel cyl new out of box 2 Radiator drain plugs new 3 Radiator drain plug washers 6 Temp sending unit new complete set of brake return springs new 1 axle Brake adjuster new out of box Brake hold down springs 2 Clutch return spring Valve seals 1 set Shock bushings 15 Pcv hose Fuel tank vent hose Misc. unidentified bolts Grille (on truck) Headlight surrounds Floor mat (complete factory rubber mat for whole floor) Interior door panels Rocker aluminum trim pieces Door mirror. Windsheild Rear Glass Rear View Mirror License plate light bulb cover Hub Caps (on truck) New Non-Factory Datsun 520 Parts TIE ROD END ES2570 TIE ROD END ES2529 KING BOLT KA330 IDLER ARM FA1038 TIE ROD END ES2340A TIE ROD END ES2339A GAS SHOCK/STRUT - FRONT 81478 GAS SHOCK/STRUT - REAR 81097
