520 engine swap
1965-1971 Datsun 521 forums. All 520 and 521 topics and discussion can be found here.
m8094538
i just got a 67 L520 with a blown motor and have access to a nice 1600 out of a 510 does anyone kno how hard this swap is and what i need to do it sucessfully the truck is all there and really straight and i have access to a 510 transmission if i need it this is my first swap soo any info u guys have would be really helpful thanx
srl311too
How bad is the motor.  I am a new owner of a 67 also and found parts very easy to find.
Cheers!
Spyder
pucancakes
i am curious too but i would like to know about putting in a sr20det. do u guys have pics of your 520s?
m8094538
it has a 5 inch square hole in the block and its a 1500 which has set since it threw the rods in 91 ide like to do a L16 swap bcuz thats a stronger and higher revving motor but i cant find any info on the swap i have a transmission for it qand everything ide just like to find sumone who has done the swap soo i can see pics of the motor mounts and how they set it up
IMH
I don't know where you got the notion that an L series engine is stronger that a J series.  Higher performance, yes, but not stronger.  J engines were used in forklifts and other industrial equipment.
m8094538
it can take more proformance abuse an Lseries will out rev a j series by far and theres way more ways to make them faster
IMH
[user=323]m8094538[/user] wrote: [quote]it can take more proformance abuse an Lseries will out rev a j series by far and theres way more ways to make them faster[/quote]All I said is that the J series is stronger if you read my post.  The L series if definately a higher performance engine.  By stronger, I meant more durable not faster.  I've been dealing with all of these engines for almost 40 years.
pucancakes
can u guys measure how long/wide/deep the engine bay is?
Return to “Datsun 520 / 521”
