520 Common parts to 320
1962-1965 Datsun L320 and NL320 forums - The truck that started it all in the US. All 320-specific topics and discussion can be found here.
odpl_Razor
Hi
Someone's selling a wreck 520 near my house and I want to know what I can scavenge/take from 520 that can be used for my N320?
Cheers
odpl_Razor
anyone?
do they have a high beam floor switch as well?
same tension/castor/radius rods?
front and rear bars?
what else can I take?
odpl_Razor
anyone?
71-521
I wish I knew more about the 320's...I do know that Datsun used parts until they ran out of them and then changed to newer versions...
some of the parts are inter changeable...I vote you grab it and use what you can and sell the rest!
:D
odpl_Razor
just took the castor rods and they are the same
did not take any other parts as I'm tired and got dark pretty quick and not knowing which one can be usefull/swappable for my 320
Pac. coast Datsun
[font="georgia"]Upper & lower control arms should be the same. Engines are similar. The J 13 transmission may bolt to the E-1 block. Yes the high beam switch is on the floors on the 520's. Id try to grab the whole truck the strip it & keep what you need.
[/font]
odpl_Razor
do they have the same brakes?
especially rear brakes?
cos I just ordered wheel cylinders for the back for 520 model as 320s are not available anymore
Pac. coast Datsun
[font="georgia"]Well I do know the 520 wheel cylinders do fit the front of the 320's so in theory they should fit the rear as well. All of the hardware should swap over too.
[/font]
matti
I have two 64 dato utes. one is being restored right now and the other is a bitser. I stripped off the brakes from both cars and they weren't interchangeable. The thread for thr stand offs on the back of the wheel cylinders were different and the stand offs were different lengths. Obviously other wheel cylinders are interchangeable but be aware of the slight differences which you may come across.
odpl_Razor
thats weird... the 520 cylinders that i bought are very identical to my 320 ones
same length and thread
australian models maybe?
tederoosky
Car: 1963 bluebird,1964 NL, 1967 411 wagon, 1974 240z, 1971 fiat spyder, 1986 mg 1100
Froand rear Brake cylinders are different, just bough both ends...a slave for the trans can be used from a 520 also...hell it looks like the Master cyl, checking that out also
Return to “Datsun 320”
