Thanks for the compliments. Zed1, here are some more pics per your request. Charlie, notice I put in the Weber32/36 already. Found a posting on Ratsun site (sorry, is it ok to mention here?) where someone suggested adapter available from JAM Engineering Corp. Bought a new 32/36DGV, the adapter (part 99004.300), universal DGV linkage, tall air filter (part 99217.332S), and universal choke cable all for roughly $350. To install, had to remove 2 original intake man studs, and replace the other 2 with longer ones (5/16" coarse about 2" long) to account for added adapter plate. Shortened and ground heads smaller on 2 hex head 5/16" coarse bolts to sink below the top plane of adapter plate - there were two bolts supplied with the adapter kit for this, but they didn't thread nicely into the intake mani - probably they were metric. I jury rigged a bell crank mech for the throttle, because the cable was aimed from the firewall pretty much straight to the throttle plate. And the way the carb bolts to the mani, the throttle plate pivots 90 degrees in relation to the cable pull direction. Found the stock cable a little too short, so made one from 1/16" steel cable and a crimp-on cable stop from Lowe's. The bell crank setup works fairly smooth, and doesn't bind - at least not yet. I'm thinking that I will change it out soon though, and go with making a long cable with sheath, just looped out and then back toward the carb - less likely to fail...
