52 Degrees BTC after timing chain replacement...HELP!!!
biotoxic07
Car: 1990 Nissan 240SX
so it has been a long 3 months. thought i could do this work over spring break and couldnt finish it. After getting the gasket i needed, i put everything back together today. it didnt start at first but did after i advance the timing. i put the timing light on and it came out to be 52* BTC....i dont know what to do...i was thinking to just move my plugs around so it dose fire at the right time....would this even work or do i have to rip everything apart again????? PLZ HELP
Razi
Car: Moo
Did you make sure to put the chain on properly?The chain and gears have marks on them so you can properly put the chain on.
biotoxic07
ya i put it on as close as i could, but the motor had a lot of slop when i was torquing everything. so i worked for a few days making sure i did it right. really the only thing that might be off is the oil pump because of the spline gear..but im REALLY close..about 30 degrees
biotoxic07
bump
480sx
Car: 1996 Pearl White 240sx
Modified by 480sx at 6:25 PM 6/19/2009
biotoxic07
lol yah any help would really be better then nothing....
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
biotoxic07 wrote: really the only thing that might be off is the oil pump because of the spline gear..but im REALLY close..about 30 degrees
Well then you need to reset the motor to TDC, make sure the cam and crank are both aligned correctly, then pull the oil pump with gear and the distributor and realign those correctly. Remember, the distributor lines up with the oil pump drive gear, so it that wasnt installed correctly, then neither is the distributor.
biotoxic07
yah i figured i would have to do it again. i was trying to figure it out without redoing.
