510 suspension question
Discussion forum for the venerable 510, and its non-US counterparts, the Datsun 1600 and Bluebird.
alvco001
Car: mx
Hi- What struts are the best for a 510. W/o major mods? I have access to a 280Z and 260Z. Both have rear drums. Are either of the Z's LSD? If so can I swap w/ my stock 160? Thanx, Tim:help
NISTECH
try this in the vintage datsun forum. datsun 411 might have your answer. better yet let me copy it to there.
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
280zx, not 280z, struts will bolt into your car with little effort, you have to change the spring perches over from the stock 510 struts. when i did this swap i just switched to coilovers in the front, from ground control. you can also find these struts in 79-82 maximas. the big advantage of this swap is the brakes though, not the struts themselves. as far as the back, use the aluminum z drums, they fit the 510, which has regular drums. or swithc to the rear disc from teh 280zx, but thats not really needed.
anything else?
510Racer
Car: Autocross, drag racing
My front struts are kinda weird. I didn't install them, they were in the car when I got it, but nonetheless, they are pretty cool. They are rear struts off of a MR2 Turbo. They have 1" diameter shafts and the strut tubes are threaded all the way down. They are also 5 way adjustable. I have a set of groundcontrol coilovers on them, and I have a total of about 10" of heighth adjustment and they handle awesome. I'm not sure what it took to install them, but maybe it something to check out. Also, I have 280z front disk brakes, that seem to work well with this strut setup.
ca18datsun510
never heard of this, you have any pics?
510Racer
I can get some and post em I guess. I can probably get some this weekend.
Turbo 510
The MR2 Rear struts are a conversion to get more suspension travel in the front. I have never heard of swapping the entire strut but a late 80's MR2 rear cartridge will fit in a 510, 810, 280ZX, etc. strut with some modifications (shortening and re-welding). It will give you about 1.5" more travel and the shocks are readily available from most of the major performance manufacturers.The best thing to do with 510 struts is to pitch them and put in a ZX or an 810. By doing that it opens up a whole world of better brakes and rotor sizes.
alvco001
Car: mx
The best thing to do with 510 struts is to pitch them and put in a ZX or an 810.WHAT DO YOU MEAN BY PITCH THEM? Tim
ca18datsun510
throw them in the garbage
alvco001
Car: mx
i get it
Turbo 510
The 510 struts have small spindle bearings and have limited brake upgrade options. By moving up to the 810/200SX/ZX struts (which have the larger spindle bearings)you can do all kinds of creative swapping for big brakes.
daniel
you could use 91 mustang GT illumina's they're even shorter than the mr2/camaro stuff
or you could put in a TRD race height..
Return to “Datsun 510 / Bluebird”
