510 Rear End
Discussion forum for the venerable 510, and its non-US counterparts, the Datsun 1600 and Bluebird.
KA24510
Car: 1989 Nissan 240sx
Well it seems as though the rear end in my 510 is out.
The rear end it had was a 92-94 Subaru Legacy Turbo Wagon and I need to replace it. Is there another rear end I can use?
The legacy rear end has a VLSD and I was kinda thinking I may as well go with a real LSD.
What will work? What else can I use?
Thanks guys...
KA24510
R160???
Is that what I want... I think it is.
Re-assure me
ztommyx
most scoobies rear end will workjust look for the gear ratio and LSD you want.
junk yard seems to have tons.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
yes, the dime uses an r160
KA24510
The R160 is what I have now apparently. I went to a subaru wrecking yard and it turns I do not need a whole new diff, just a new stub axle or stub end for the datsun axle and that is proving to be very hard to find...
This is the part I need a new one of, the red circle is where it is stripped and wont grab to turn the axle
Any body have one of these or know where I can find one? Also, is this part the same on any other car besides a 510?
yellowcar
KA24510
yellowcar wrote:Read this...
http://kmhafer.datsun510.com/Subaru.htm
Thanks alot for that dude, good looking out
I had read quite a bit about different differential's but this helped some more.
Thanks again
yellowcar
No problem, been doing the 510 thing for a long time...
KA24510
Well Im hoping to hold on this for a while. So far it has been annoying but hopefully (fingers crossed) it will be back on the road today...
KA24510
Axles are in and the car is rolling once again.
Tomoro I will installing a stiffer set of shocks to avoid this in the future as well as putting the bumpers and grill on.
Pics will be up then too
tfram2003
Car: 1970 510 sr20
you can try the early r180 stub axles. i have heard they are the same spline count but longer and less prone to break. i broke 2 axles with my sr and i am gonna try r 200 but soon i will be pushing 400 or so hp. zer...71029#
Return to “Datsun 510 / Bluebird”
