mixeds14 »
https://forums.nicoclub.com/mixeds14-u90592.html
Tue Nov 16, 2010 10:21 pm
so i finally got some coils for my 95 se n im puttin the se oem 5 spoke rims back on there until i get tires for my 18..witch are +20 offset, i know those dont rub the coil but the factory rims do.. i have searched n cant get a clear answer on this.. i keep reading that the 60mm are to long n the 50mm u can only run a 5mm or so spacer on there but is that enough to clear the coil n z32 brakes..
i know i can get the 60mm n run open lugs on there but wont that look goofy with the rest of the stud stickin out?...
so what studs are yall running with the factory rims n what size spacer?...... which would be better....
