Kendahl wrote:There are two problems with quick oil change places.
The first is that they are at the bottom of the pile in terms of technical proficiency of their employees. Some shops carefully train their employees, but many don't. Either way, they are not fully trained mechanics and are not qualified for anything beyond oil and filter changes.
The second is that, to pad their sales, they peddle all kinds of crap. Too many customers are taken advantage of because they don't recognize the crap for what it is. At best, the crap is simply a waste of money. At worst, it causes damage that has to be repaired by a competent shop, usually at the customer's expense.
I've never heard of cleaning a fuel pump. This is just more of their crap. Unless the pump breaks, all you should ever need to do is replace the fuel filters (there may be more than one). Do this as specified in the service schedule. If you get a tank of dirty gas, you might have to replace the tank filter early, but that's all.
Modern cars don't even have replaceable fuel filters either. With most cars that use a returnless fuel system, the filter is integrated into the pump assembly.
And Jiffy Lube is a joke. I can tell you, sadly, as a former employee of Jiffy Lube (freshman year of college, but I quit due to the fact they were all dumbasses), they make up random crap all the time. They have no training, other than to try and upsell as many services as they can. There is probably one car out there that had a clogged fuel pump that they had one time, so this is reason for them to try to sell this service on all cars going forward. It's a huge scam.
I read through my maintenance manual on my G and if you look at just the required services, the only thing between new and 120k miles is oil changes, and air filter changes. Everything else just says to inspect. Now I'll probably change things like gear oil and diff oil, but that's just because I want to, not because it needs it.
