gawdzilla »
https://forums.nicoclub.com/gawdzilla-u19868.html
Tue Sep 06, 2005 6:42 am
is the exhaust camshaft itself damaged? try to shine a light in there and see if you still have the mating surface there on the camshaft. use some qtips or something and try to clean it out some so you get a clean mating next time. i would imagine the CAS mating half is much more fragile than the cam half. it seems like its pretty easy to mess up the CAS half of the mating teeth when installing, just be gentle when pushing it in. it only goes on one way i'm sure you know that. also on your replacement CAS, use some brake cleaner and qtips. i found that the inside of mine had some random gunk in it, probably old grease or something.
just giving some advice, i'm sure you already know this. i tried a bunch of different turns with my CAS before it went in smoothly. good luck, keep us posted
