5000 or 6k to spend
Morph
Car: 91 Sr Powered Coupe
Hey guys i've come to the conclusion that buying part by part is going to take way to long and i've decided to take out a loan. I have a Completely stock Sr. Im looking for 350 to the wheels and was looking to use the Gt2871R as my turbo. Now my question is is 5 or 6k enough for this goal?Should i get an ecu tune or a stand Alone?What kind of internal work is going to have to be done to hit 350 safely?
And any other opinions would be grately apreciated.
Thanks again.~Morph~
S14Life
Car: b5 s4 stage 3, 2001 pathfinder, 91 s10
For 350, you really don't need to change anything except maybe getting longer duration cam. Turbo, front mount intercooler, larger injectors, something to run the injectors (stand alone or piggyback), boost controller, full 3" exhaust, normal stuff. But as far as engine work the only thing you would need do it upgrade the cams. The bottom end is "bullet proof".
240DRFT
you'd might want to get some rocker arm stoppers...you might be able to just use a piggy-back ecu
Morph
Um what kind of up agraded cams and were would i get the rocker arm stopers555cc or 750cc injectors?
240DRFT
http://www.jgycustoms.com has rocker arm stoppers for $66... enjuku racing and phase2motortrend have a selection of HKS cams, along with other sr20 parts
