WDRacing wrote:Looks like it's going to be an awesome build. I'm just going to throw my .02 out there.
THIS Turbo
Go with meth or propane injection instead of E85. Not only does it allow you to run pump gas, but you can easily tune past your injectors max duty cycle. This will let you run a Enthalpy ROM tune, the N62 MAF and give you the ability to run any amount of boost you want with little to no timing retard. This will give a huge hp to psi ratio so it will require far less boost to reach your goals, which is always a good thing IMO. You should be able to clear 500 ftlbs without crossing 30lbs of boost or you're not using the correct turbo.
I'm going with propane only because it's far cheaper then methanol![]()
WD
I was refering to the billet 6057. It should be a nice mix between the FP3065 and the HTA3582r. The PTE HP billet line is ALOT cheaper then the FP products and very similar in flow. THe HP6262 has been proven to out flow the HTA3582 for almost half the money. I still like the BW S362 but they are larger framed turbos and closer to the cost of Garrets.GTR PrYdE wrote:My bet is on a HTA3582R .63 from Forced Performance, on e85 with alot of boost, you'll make a ton of torque and still be 600whp+ capable
It's an expensive turbo, but you get your cake and eat it too
Don't waste your money on a 6057, opt for the Billet 5857 instead, newer more efficient design.
It will def out spool the Billet 35r but won't make as much hp up top
I have two friends with built and balanaced bottom ends, supertech valve springs, and either JWT or kelford cams and they both rev limit at 8K and shift between 7500-7800. Both have been doing this for 1-2 years and one of them DD's his car. I plan on rev limiting at 8K and letting it eat. If it comes apart next summer you can all say "I told you so". From my experience that isn't going to happen. There are more than 10 people on KA-T that rev that high with a balanced stock crank and aftermarket cams and springs.Marahutay wrote:i second that. i have the same motor head as you and i also have a built bottom end with cp pistons + bored out with eagle rods, including having my crank balanced within a half gram and everyone on here has told me i wont be safe past 7300 even still
That's what I'm talking aboutkentuckyslider wrote: I plan on rev limiting at 8K and letting it eat.
man, you are fine.SX APPEAL wrote:Yeah, basically just did it to see how high it would let me go, didn't actually hit the limiter either, but I was too scared to go any higher. How much of a difference do cams make with the turbo? Are they worth the $500-$600 when you could just turn up the boost knob for free? Sorry to thread jack kentucky, I'll shut up after this
First of all I will be revving to 7800 with a rev limit at 8K and that will ONLY be at the track, dyno, or if I have a roll race that is close enough to merit winding it out.(there won't be manyCrazyirish wrote:I think someone should point out the difference between winding an engine out to 8 grand every once in awhile VS. engine's maximum safe constant rpm.
WDs point is also solid though. Unless you've got the flow, why bother? If you've got the flow, then knock yourself out. Maybe some piston speed calculations would be in order. I'm just very leary of anecdotal evidence when it comes to such things. I can't tell you how many times I've heard: "Oh yeah, I rev that bish up to like 9.5 all day long!" And its usually from some kid driving a stock camry.
That calculation doesn't really tell you much. The piston moves much faster at the top and bottom of the cylinders than average piston speed suggests. FWIW I agree that the half counter weighted crank is the biggest obstacle for high rpm power. Even if everything else is in order, you're fighting some pretty serious harmonics.SX APPEAL wrote:I researched a high revving ka project a while back. Piston speed is a pretty simple calculation, MPS = 2 x Stroke x RPM / 60
stock KA stroke is 96mm, which you divide by 1000 to get that length in meters, so the equation for 8K RPM would be:
2 x 96/1000 x 8000/60 = 25.6m/s.
Just for comparison, the old Honda S2K that revved to 9 grand:
2 x 84/1000 x 9000/60 = 25.2m/s
So 8000 is within the realm of possibility, even for a factory stock engine, albeit a very high performance one. So basically its not the piston speed thats going to screw a high rev KA, its the half weighted crank.
