check this out
d Norris Designs RS13 CA18DET ND540
Owner:Richard BeaumontPhone:+44 1249 712024E-Mail:
[email protected]:16.08.04Engin Mods:CA18DET 1809cc Turbo8800Rpm Rev Limit511.5 Hp At The Hubs613.8 Hp At The Flywheel458.3 LbFt At The Hubs
Geared Top Speed 200Mph+Best Top Speed So Far 186MphND Forged PistonsND Chrome Piston RingsLightened & Balanced Bottom EndND Twin Plate Clutch & Custom FlywheelND Steel Billet CrankshaftTrust Steel ConrodsND Lightweight Solid LiftersHKS CamshaftsTomei Wide Coil Valve SpringsTomei Adjustable Cam PulleysND Race Spec Cylinder Head (GT Combustion Chambers)SARD 1000cc Fuel InjectorsFull Dash 8 Fuel LinesND Large Bore Alloy Fuel RailND Prototype Large Throttle Inlet ManifoldSARD Adjustable Fuel Pressure RegulatorBosch Motorsport Gp B Fuel PumpND Full Engine Management SystemFull Greddy Turbine Kit TD06-25GND Prototype Front Mounted Intercooler3" Intercooler PipeworkSamco Blue HosesND Breather SystemUndisclosed Compression RatioK&N Induction KitHKS Super Dragger Full Exhaust System3 Bar Map SensorMotec M4 Pro Engine ManagementND Custom Full Engine HarnessRemote Mounted Battery With Alloy CoverTransmission:OS Giken Long Ratio GearboxND 800Hp Twin Plate Clutch KitND Quickshift KitInterior Mods:ND Boost Gauge KitOil Pressure GaugeOil Temp GaugeWeber Alpha Lambda MonitorGreddy B Spec Boost ControllerGreddy Turbo TimerSparco Bucket SeatsChassi Mods:Leda 2.5" Race Coilover Suspension KitNismo Rear Sub-Frame Bushes (X 4)Lowered 80mm All RoundBrake Mods:ND 355mm Front Brake KitGoodridge Braided HosesMintex Synthetic Brake FluidMintex F4R Front PadsWheel Mods:18" X 7.5" Khan RSR'sAvon 7000 225/40/18 TyresSound Mods:None Needed!Buildtime:5 YearsCost:£50,000 PlusAwards:Most Powerful CA18DET Outside JapanThanks:PLEASE WAIT FOR THREE IMAGES TO LOAD ON RIGHT!
Images, text from
http://www.norrisdesigns.com/ under ND Demo Cars button on leftCa18det FTW!!!
