your retarded24j0hn wrote:youll need to bore deck and hone the cylinders about .20"... get low compression forged pistons and rods... gt28 turbo or higher... 570cc or higher injectors... upgraded valves and springs and cam to be safe...
**** ** ** ****** **** *** stupid ** **** ****!!!xX RB Xx wrote:
your retarded
ummm why didnt you edit and remove stuff that doesnt add power????hpmachine wrote:500+whp T28 won't even get you half way there. look at these build specs... this put down over 500whp but again it was DOHC...
?¡Precision PT61 .68 ar turbine?¡Revhard manifold?¡Nsport downpipe?¡GP Sports 3" exhaust?¡Nposrt intercooler and piping?¡Tial 38mm wastegate1bar spring?¡TurboXS RFL bov?¡9:1 Ross forged pistons, Pauter rods, ARP head and main studs, 3 angle valve job, Cometic headgasket, S13 cams?¡Clutchmaster's stage 5 clutch and Fidanza flywheel?¡Joe P manual boost controller?¡Groundzero engine and transmission mounts?¡JWT ECU programmed for MSD 72lb injectors and Z32 mafs?¡JGY top feed fuel rail w/ 75# injectors?¡B&M mechanical fuel pressure gauge?¡ThermoTec turbine blanket and header wrap?¡Autometer mechanical fuel pressure gauge?¡Taylor spark plug wires and NGK BKR7E-11 plugs?¡MSD 7al2 ignition?¡Apex-I SAFC?¡PLX devices M300 wideband?¡MSD knock alert meter?¡MDM Techtom?¡B&M Short Shifter?¡Autometer 52mm Phantom Gauges (Boost, EGT)
oh FFS get a holset, GT is for low end s***nightsleek240coupe wrote:the t3/t4 is just not going to cut it. look into a gt30/35/40 or a big holset.
that is exactly what i was going to sayhpmachine wrote:Really? I'd say everything there is pretty important. If not related directly to making power, a lot of those things are a necessary part of the complete setup. The point is, there is a lot that goes in to making 500hp SAFELY. It's not just about throwing on a big blower and tuning it.
I don't know why people say this kind of stuff either. I jumped from a stock Jetta in to a 380hp S13 and never had a problem. Just use your head and take time to adapt. But I suppose maybe the OP is really stupid. LOLkouki munster wrote:So, your going to go from the stock single slammer power levels, and go straight to 500 hp. Hmmmm....... am I the only one seeing a massive fiery crash in this guy's future?
he can reach his dream on pump gas. (93 octane)http://www.ka-t.org/forums/vie...art=0h ... hp?t=43858hbpignosePA wrote:you got big dreams
step into the rb world or the LS mods instead. less to worry about and a more durable platform that was meant for speed instead of a truckfabios s13.5 wrote:i have a sohc ka24e just want to get some opinions and also when i looked through diff forums nobody says were and how much things are haha so hope this helps others in their search. btw these engines have hit 945hp range wow didnt know they could b4.so i am doing a rebuil with turbo addition
awep.comrod bearings/mainfull gasket settiming kit oil pumpwater pump $ 327.85+8.95ship
amsperformance.compistonsmain/head studs $720+?ship
turbochargers.comeagle rods $318.75+?ship
frsport.comvalve springs and retainer kit $359.95+?ship
estimated engine rebuild $2100.00
Turbo build
i have t3/t4 60greddy RStial 38mmcxracing.com intercooler and piping $300jimwolftechnology.com ECU $595+?shipO&J performance750cc inj $400 setfuel pump $239.99stage 2 cam (optional) $174.99
