accel junky »
https://forums.nicoclub.com/accel-junky-u15161.html
Tue Nov 30, 2004 8:35 am
Well, today marks the 6th month and 500+ hours I have spent on my S13 RB project. It still does not run. I desperatley need some help and suggestions. I wll try to lay this post out as organized as possible.
Relevant Mods:-------------------Nismo FPRWalbro 255lphPE 550cc InjectorsAftermarket turbo/wastegate (brand new)FMICQ45 MAFApexi Power FC
Whats happening now?------------------------------Tried to start the car with the MAF attatched directly to the throttle body (waiting on greddy manifold, cant run IC piping due to top mount turbo). All disconnected vacuum lines were duct-taped over.
First couple of times was with MAF disconnected. Had to hold throttle at 3/4 to get it to start up and it would not idle on its own. All the while there was a large amount of smoke coming out of the turbo. I suspect it was oil burning, had a SLIGHT bluish tint and smelled like burning oil. Power FC was used.
Second set of time were with the MAF connected. This time I only had to hold the throttle at 10% or so to get it running and it still wouldnt Idle on its own. Same situtation with smoke. Power FC was used and then switched to stock ecu, no difference.
Both times the Power FC was set for the Q45 MAF. Both times the in-line Fuel Pressure gauge was not reading at all, although the engine was OBVIOUSLY getting fuel as I put a old tshirt behind the turbine and out came lots of carbon and unburned fuel turning the shirt black and wet with gas.
I have an extra set of Coil Packs and an extra entire RB25 EFI harness to try if necessary.
What have I tested?-------------------------My multimeter is analog and from the 1970's at least. I don't get anything near what the R33 FSM says in terms of voltages and resistances, quite frankly because the FSM contradicts itself and maybe because I am not electronics savvy in any way.
Fuel Pump comes on as it is supposed to.
Power FC has constant power as it is supposed to.
Tried to wire the the start signal to the ecu, but all I had to go on was an "orange wire from the dash harness to pin 43". That didn't change anything in terms of starting the motor. The orange wire was for the s14, so I'm not sure if its different for my S13.
Conclusions:----------------
Anyhow, thats about it. I'm currently wasting the rest of my money on the Greddy intake manifold so I can actually run my IC piping. At the same time I will replace everything I can with the factory gasket kit that I bought for the motor.
If anyone has any suggestions or solutions, please, please help me out. I don't think anyone has encountered as many problems as I've had.
Thanks a ton,Daniel
Modified by accel junky at 1:51 PM 11/30/2004
